BDM locks up occasionally on overnight tests
Joe Novosel
jnovosel at broadcom.com
Wed Oct 10 22:11:51 UTC 2001
It's probably that the ribbon cable from the pc to the bdm board is too long
(~ 4 feet) and it's unshielded (bdm cable came this way).
Joe
On Wednesday 10 October 2001 13:16, Efren Serra wrote:
> Joe,
> Talk about Signal Integrity (SI) issues!
> Efren Serra
> > I've had the same problem.
> > It was electrical noise resetting the board. When I turned off my lights
> > (florescent) sometimes my target board / bdm locked up. I'm using the 5
> > chip bdm board with a 68360 board.
> > I tried starting the test again (with the lights off) and it ran
> > overnight without any problem.
> > Hope this helps.
> > Joe
> > On Tuesday 09 October 2001 12:57, Benshoof, William {AVL~Roswell} wrote:
> > > We are using RTEMS with a P&E ICD_BDM, GDB 4.18/DDD 3.2.1/Pavel's
> > > patches, and a Motorola 68332 CPU. Overall, our setup is very stable,
> > > and we aren't having significant troubles. However, when we set up a
> > > test to run overnight or for several hours, sometimes we get an
> > > unexpected (and inexplicable) interrupt.
> > > We're going to be running this sort of test out of ROM as well as with
> > > the BDM. We're also working on implementing leak-detection and usage
> > > statistics, and we have the stack checker turned on.
> > > Any ideas on what we might find? Is there a "this happens sometimes
> > > with the BDM" category?
> > > Bill
> > Content-Type: text/html; charset="iso-8859-1"; name="Attachment: 1"
> > Content-Transfer-Encoding: quoted-printable
> > Content-Description:
> > Joe Novosel
> > Test Engineer
> > Broadcom Corporation
> > Residential Broadband Unit
> > 770-232-0018
Joe Novosel
Test Engineer
770-232-0018
