PowerPC MBX8xx Build Failure Question
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Oct 18 12:07:23 UTC 2001
This is caused by the mpc8xx libcpu timer driver depending
on macros defined ONLY in the old_exception_processing
side of the powerpc. I am considering treating both
values as 0 for now since that is valid. Comments?
Joel Sherrill wrote:
> I am trying ot resolve build issues before cutting a new
> snapshot. RTEMS snapshots are not cut automatically.
> There is always an attempt to make sure at least
> certain BSPs are in reasonable shape. In my last
> sweep, I tripped over a failure in the mbx8xx BSPs. So...
> Where are these symbols supposed to come from?
> ../../../../../eth_comm/lib/librtemsall.a(timer.o): In function
> `Read_timer':
> /usr1/rtems/build/build-powerpc-rtems/powerpc-rtems/c/eth_comm/lib/libcpu/powerpc/mpc8xx/timer/../../../../../../../../../current/c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c:85:
> undefined reference to `rtems_cpu_configuration_get_timer_least_valid'
> /usr1/rtems/build/build-powerpc-rtems/powerpc-rtems/c/eth_comm/lib/libcpu/powerpc/mpc8xx/timer/../../../../../../../../../current/c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c:88:
> `rtems_cpu_configuration_get_timer_average_overhead'
> Thanks.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
