rtems_event_receive and timeslicing
Brett Swimley
brett.swimley at aedinc.net
Tue Oct 23 16:33:03 UTC 2001
I'll try knocking the ticks_per_timeslice down, and try it again.
I do have a clock driver. I've verified it is running and calling
rtems_clock_tick.
However, fundamentally, my perceptions aren't wrong? The blocked task
should run in this situation when it gets the timeslice?
Thanks,
Brett
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Sent: Tuesday, October 23, 2001 9:58 AM
> To: brett.swimley at aedinc.net
> Cc: 'RTEMS'
> Subject: Re: rtems_event_receive and timeslicing
> Brett Swimley wrote:
> > I have a situation where I have two tasks running at the
> same priority (=
> > 128). Both tasks were created with RTEMS_PREEMPT and
> > RTEMS_TIMESLICE.
> > One task is blocked, waiting on an event that is sent by an
> ISR. The other
> > task is in an infinite loop as follows:
> > for ( ;; )
> > The task that is blocked on the rtems_event_receive() never
> appears to
> > receive the event. However, if I place an
> > rtems_task_suspend( RTEMS_SELF );
> > call prior to the infinite loop in the 2nd task - the first
> task does
> > receive the event.
> > I won't have this task construct in the near future as I
> implement more
> > functionality, but I would like to understand if the
> blocked task should run
> > under this situation with timeslicing enabled. If I am missing some
> > configuration options as well, I would like to know.
> > I have
> > #define CONFIGURE_TICKS_PER_TIMESLICE 50
> > in my Initialization function file.
> > I'm currently using the rtems-ss-20010816 snapshot.
> My guess is that you don't have a clock driver. Or that you do
> and the time quantum is larger than you think based upon
> CONFIGURE_MICROSECONDS_PER_TICK and
> (CONFIGURE_TICKS_PER_TIMESLICE == 50).
> A 10 millisecond tick (the default I think) and 50 ticks per
> timeslice is 1/2 second per timeslice.
> > Thanks for any insight.
> > Regards,
> > Brett Swimley
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
