RTEMS 4.5.0 and standard PC keyboard
Motiwala, Yusuf Ibrahim (Yusuf)
motiwala at lucent.com
Sat Sep 1 07:57:15 UTC 2001
Right, It worked after configuring clock driver. Thanks for precise input.
However, I am not sure why RTEMS developer decided to go with this approach.
I feel blocking mechanism (may be using semaphores) could have been more
efficient and cleaner than polling.
Regars,
Yusuf
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Tuesday, August 28, 2001 11:41 PM
To: Motiwala, Yusuf Ibrahim (Yusuf)
Cc: 'rtems-users at oarcorp.com'
Subject: Re: RTEMS 4.5.0 and standard PC keyboard
"Motiwala, Yusuf Ibrahim (Yusuf)" wrote:
> Hi,
> I started trying out RTEMS 4.5.0 on standard PC. Everyhing
> went fine and I was able to run samples, picoTK etc without
> any problem. However, I am not able to get the keyboard working.
> The keyboard is normal PC 101/102 keys with 8042 compatible
> controller so I assumed there should not be any problem.
> While tracing, I made sure that RTEMS keyboard ISR is
> getting executed. Can anybody help me getting keyboard working.
My guess is that you based your test on hello, don't have
a clock tick driver configured, and the keyboard driver polls
using a clock tick to control itself. See ticker for how
to configure a clock tick.
And BTW are you part of the group that ported RTEMS to a
Lucent DSP? All my contacts disappeared (one was an co-op)
and I would like to see that effort included in the standard
distribution. I can provide names if that helps.
> The simple program just uses
> printf("Enter String: ");
> gets(someString); /* or fgets with bound*/
> printf("Sting is %s\n", someString);
> Regards,
> Yusuf
joel at OARcorp.com On-Line Applications Research
