Tue Sep 4 00:44:40 UTC 2001
charles at embsyspro.com wrote:
> Hi,
> I am compiling the most recent snapshots.  I am compiling for
> mips64-elf-rtems.  I have installed all of the patches and Binutils compiles
> fine.  But gcc breaks with the following error;
> xgcc: installation problem, cannot exec `mips-tfile': No such file or
> directory
> make[1]: *** [libgcc1-asm.a] Error 1
> make[1]: Leaving directory `/cygdrive/e/rtems_snapshots/build/gcc'
> make: *** [all-gcc] Error 2
> Can someone identify this error?
This is a fairly common cross mips error but I don't know what tool
configuration ou are using.  The only two official RTEMS targets
are "mips64orion-rtems" and "mips-rtems".  I recommend using
mips-rtems along with the prebuilt tool binaries.
> Thanks,
> CLN :-)
>    winmail.dat    Type: application/ms-tnef
>               Encoding: base64
