(No Subject)
latish sudheer
latish_sudheer at lycos.com
Fri Sep 7 12:20:01 UTC 2001
Hi,
I am very new to rtems.I am trying to install it on cygwin on NT.
I have followed the following procedure.I am getting some errors when i tried to install gcc.
Please help me.
- Created a directory called "rtemsarchive" and download the source code
for GCC, newlib, binutils & GDB into that directory from "www.oarcorp.com".
For the latest version of the code download the "RTEMS Snapshot access".
gcc 2.95.2
FTP Site: oarcorp.com
Directory: /pub/rtems/snapshots/c_tools/source
File: gcc-2.95.2.tar.gz
URL: ftp://oarcorp.com/pub/rtems/snapshots/c_tools/source/
sudheer:->done
binutils 2.11
File: binutils-2.11.tar.bz2
sudheer:->done
newlib 1.9.0
File: newlib-1.9.0.tar.gz
sudheer:->done
gdb 5.0
File: gdb-5.0.tar.gz
sudheer:->done
Download the patches for the above tools. Patches are the files with extension
".diff".
RTEMS Specific Tool Patches and Scripts
FTP Site: ftp.OARcorp.com
File: binutils-2.11-rtems-20010409.diff
File: newlib-1.9.0-rtems-20010221.diff
File: gcc-2.95.2-rtems-20010221.diff
File: gdb-5.0-rtems-20010314.diff
- Start cygwin.
- Create "/source/rtems" directory under the root. Enter the foll. command
"mkdir /source/rtems".
sudheer:->done
- Create a directory under root called "/build/rtems" for the building the
toolset.
"mkdir /build/rtems".
sudheer:->done
Building Binutils:
- cd /source/rtems
- Execute the following command
bunzip2 /rtemsarchive/binutils-2.11.tar.bz2
This should create a binutils-2.11.tar under /rtemsarchive directory.
sudheer:->done
- Extract the files from the "binutils-2.11.tar" archive.
tar xvf /rtemsarchive/binutils-2.11.tar
- After unpacking the tar file a directory "binutils-2.11" will be created under
/source/rtems.
sudheer:->done
cd binutils-2.11
patch -p1 < /rtemsarchive/binutils-2.11-rtems-20010409.diff
sudheer:->done
cd binutils-2.11
find . -name "*.rej" -print
sudheer:->done no "rej" files found
- cd /build/rtems. Then create a directory "binutils" .
mkdir binutils.
cd binutils
- Invoke configure and make to build and install binutils-2.11 for i386-rtems target:
/source/rtems/binutils-2.11/configure --target=i386-rtems \
--prefix=/opt/rtems
make all
make info
make install
sudheer:->done
- Add the directory containing the executables to your PATH. Usually all the
executables are stored in "/opt/rtems".
sudheer:->done
I have done lik PATH=/opt/rtems:$PATH
export PATH
Building GCC & Newlib :
- cd /source/rtems
- Extract the files from the "gcc-2.95.2.tar.gz" archive.
tar xzvf /rtemsarchive/gcc-2.95.2.tar.gz
sudheer:->done
- After unpacking the tar file a directory "gcc-2.95.2" will be created under
/source/rtems.
sudheer:->done
cd gcc-2.95.2
patch -p1 < /rtemsarchive/gcc-2.95.2-rtems-20010221.diff
sudheer:->done
- Check to see if any of these patches have been rejected using the following sequence:
cd gcc-2.95.2
sudheer:->done
No "rej"files found.....
- cd /source/rtems
- Extract the files from the "newlib-1.9.0.tar.gz" archive.
tar xzvf /rtemsarchive/newlib-1.9.0.tar.gz
- After unpacking the tar file a directory "newlib-1.9.0" will be created under
/source/rtems.
sudheer:->done
cd newlib-1.9.0
patch -p1 < /rtemsarchive/newlib-1.9.0-rtems-20010221.diff
cd newlib-1.9.0
sudheer:->done
sudheer->i have done
PATH=/source/rtems/binutils-2.11/binutils:$PATH
PATH=/source/rtems/binutils-2.11:$PATH
export PATH
sudheer:->done
I HAVE DONE LIKE
ln -s /source/rtems/newlib-1.9.0/newlib
- Invoke configure and make to build and install gcc-2.95.2 for the i386-rtems target:
cd /build/rtems
mkdir gcc
cd gcc
/source/rtems/gcc-2.95.2/configure --target=i386-rtems \
--with-gnu-as --with-gnu-ld --with-newlib --verbose \
--enable-threads --prefix=/opt/rtems
sudheer->done
make all
sudheer->
I am getting two errors.
/source/rtems/gcc-2.95.2/gcc/libgcc2.c;301:parse error before 'uu'
make[3]:***[libgcc2.a] Error1
make[1]:***[all-gcc]error 2
make info
sudheer-> done
make install
Sudheer->
I am getting errors like
make[1]***[crtbegin.o]Error 1
make[2]:leaving directory '/build/rtems/gcc/gcc'
make: ***[install-gcc]error 2
can any one help me regarding.
with regards
sudheer
Get 250 color business cards for FREE!
http://businesscards.lycos.com/vp/fastpath/
