about getcwd
Camilo Alejandro Arboleda
camilo.arboleda at ascom.com.co
Fri Sep 7 22:03:59 UTC 2001
If you are using RTEMS 4.5.0, there is a bug in imfs readdir (file imfs_directory.c), about line 115
The code is
if( current_entry >= first_entry ) {
/* Move the entry to the return buffer */
tmp_dirent.d_ino = 1; // IT DOESN'T WORK WITH GETCWD
tmp_dirent.d_off = current_entry;
tmp_dirent.d_reclen = sizeof( struct dirent );
the_jnode = (IMFS_jnode_t *) the_node;
tmp_dirent.d_namlen = strlen( the_jnode->name );
strcpy( tmp_dirent.d_name, the_jnode->name );
memcpy(
buffer + bytes_transferred,
(void *)&tmp_dirent,
iop->offset = iop->offset + sizeof(struct dirent);
bytes_transferred = bytes_transferred + sizeof( struct dirent );
The problem is that d_ino has not a valid value, so getcwd cannot realize what the current directory is. The next code works (it appears that way in more recent snapshots)
tmp_dirent.d_ino = the_jnode->st_ino;
memcpy(
----- Original Message -----
To: rtems-users at oarcorp.com
Sent: Wednesday, September 05, 2001 5:27 PM
Subject: about getcwd
Anyone who can help me to explain these problems in getcwd().
* If it's a mount point, have to stat each element because
* the inode number in the directory is for the entry in the
* parent directory, not the inode number of the mounted file.
save_errno = 0;
if (s.st_dev == dev)// When use this, it's not work.
for (;;)
if (!(dp = _readdir (dir)))
goto notfound;
if (dp->d_ino == ino) // dp->d_ino is always be 1. It has been set in imfs_dir_read (imfs_directory.c).
break;
else // This is work.
for (;;)
goto notfound;
if (ISDOT (dp))
continue;
bcopy (dp->d_name, bup, strlen (dp->d_name) + 1);
/* Save the first error for later. */
if (stat (up, &s))
if (!save_errno)
save_errno = errno;
errno = 0;
continue;
if (s.st_dev == dev && s.st_ino == ino)
break;
Thanks,
Tu Juan
URL: <http://lists.rtems.org/pipermail/users/attachments/20010907/d746b7be/attachment.html>
