Microwindows and RTEMS
Rosimildo da Silva rdasilva at connecttel.com
Mon Sep 10 11:48:19 UTC 2001
To: <rdasilva at connecttel.com>
Sent: Sunday, September 09, 2001 8:49 PM
Subject: Microwindows and RTEMS
> Hi
> Im trying to use Microwindows with RTEMS.
> When I try compile the demos I get the error: "ld: cannot
find -lmwimages".
> Can you help me?
Yan,
I am not working with RTEMS recently, so I do not have a test system
available.
Did you check if the "libmwimages.a" has been built ?
Maybe this library has been added recently.
Post this to the list, maybe someone else is using MW right now,
and probably in better shape to help you.
Rosimildo.
