Memory region tracking similar to malloc_stats?
Phil Torre ptorre at zetron.com
Tue Sep 11 19:57:29 UTC 2001
Hmm.  Grepping my source tree, I don't have malloc_free_space,
rtems_region_get_information, _Heap_Get_information, or
Heap_Information_block.  Is this the price I pay for loitering
back at 4.5.0? :)
(If so, can I get the required code from a snapshot, or has the
heap code changed too much?)
Many thanks...
On Tue, Sep 11, 2001 at 11:07:43AM -0500, Joel Sherrill wrote:
> Phil Torre wrote:
> > Is there a simple way to access the current amount of space remaining
> > in a region?  Something like malloc_stats would be great, but I don't
> > actually need the allocation history so much as the current free
> > space (so as to watch for get_segment/return_segment leaks).
> > It looks like the right thing to do is to walk the heap blocks like
> > _Heap_Allocate() does, but I'll save myself some fumbling around if
> > this work has already been done.  Thanks...
> How about this routine? :)
>  *  Find amount of free heap remaining
> size_t malloc_free_space( void )
> It is based on the rtems_region_get_information()
> call.  It can return the following info:
>  *  Information block returned by _Heap_Get_information
> typedef struct {
>   unsigned32   free_blocks;
>   unsigned32   free_size;
>   unsigned32   used_blocks;
>   unsigned32   used_size;
> } Heap_Information_block;
Phil Torre                               phone: 425-820-6363 x234
Design Engineer                          email: ptorre at zetron.com
Switching Systems Group                    fax: 425-820-7031
Zetron, Inc.                               web: http://www.zetron.com
