Building PowerPC eth_comm
Greg Marsden GMarsden at WESCAM.com
Mon Sep 17 21:00:14 UTC 2001
Numerous places in the build are failing because of the missing
bsp_specs file, e.g.
make[5]: Entering directory
`/d/users/gmarsden/rtems-test/powerpc-rtems/c/eth_co
mm/exec/posix/src'
mkdir o-optimize
/opt/rtems/bin/powerpc-rtems-gcc --pipe -B../../../../../../eth_comm/lib/ -s
pecs
bsp_specs -qrtems -g -Wall -ansi -fasm   -DPPC_VECTOR_FILE_BASE=0x00000000 -
mcp
u=860     -c -D__RTEMS_INSIDE__ -O4 -fno-keep-inline-functions -o
o-optimize/ada
supp.o /d/users/gmarsden/rtems-4.5.0/c/src/exec/posix/src/adasupp.c
powerpc-rtems-gcc: bsp_specs: No such file or directory
I am using rtems-4.5.0 on cygwin.
Should bsp_specs be automaticly installed in the build tree?
Thx - Greg
