termios and raw data - bug?
Wed Sep 19 11:13:08 UTC 2001
peter.o.mueller at gmx.de wrote:
> > That seems a little complicated.  Would not
> >       return (unsigned char)((*getReg)(pNS16550, NS16550_RECEIVE_BUFFER));
> > work properly?
> Who takes care about the changes. Joel, do you patch the serial driver code?
I know I care and suspect that others care as well. :)
In this type of case, I fall to my virtual knees and beg you to fix it
in the BSPs you can test and make a stab at the others.  This is what I
have had to do many times when a change impacts every BSP.  Just be
careful.
I will merge a patch.
> Peter
> GMX - Die Kommunikationsplattform im Internet.
> http://www.gmx.net
