network boot
Eric Norum eric.norum at usask.ca
Wed Sep 26 14:42:54 UTC 2001
Davide Del Vento wrote:
> Hi all.
> I would like to configure RTMES (on a PC104 and with a 3c509 Ethernet card)
> to obtain a boot via network (NFS? FTP?). I found something on this archive,
> eg. the threads:
> http://usa.oarcorp.com/rtems/maillistArchives/rtems-users/2001/april/msg00076.html
> http://usa.oarcorp.com/rtems/maillistArchives/rtems-users/2001/april/msg00065.html
> but I miss something...
> Could someone give me some suggestions?
Chris is the expert on this, but I'll throw in my $0.02 anyhow.
I use etherboot to boot my PC targets.  I picked up the bootstrap PROM
image from http://www.rom-o-matic.net/.  Here's the script I use to
produce a netboot image from the xxxxxx.exe produced by the RTEMS
application makefiles.
#!/bin/sh
set -e
case "$#" in
	1)	;;
	*)	echo "Usage: $0 file.exe" >&2 ; exit 1 ;;
esac
n=`basename "$1" .exe`
code=2
trap 'rm -f /tmp/jnk$$.bin ; exit $code' 0 1 2 3
i386-rtems-objcopy -O binary "$1" /tmp/jnk$$.bin
/opt/rtems/i386-rtems/pc386/build-tools/bin2boot -v "$n.bt" 0x00097E00
/opt/rtems/i386-rtems/pc386/lib/start16.bin 0x00097C00 0 /tmp/jnk$$.bin
0x00100000 0
code=0
I put the resulting xxxxxx.bt image on my TFTP server.  The PC starts
up, gets its IP information from my DHCP server and downloads the
executable using TFTP.
Department of Electrical Engineering       Phone: (306) 966-5394
University of Saskatchewan                 FAX:   (306) 966-5407
Saskatoon, Canada.
