to make a prom image...
Joel Sherrill joel at OARcorp.com
Fri Sep 28 00:15:30 UTC 2001
Which BSP is this with or close to?  I would like to tinker with this
myself.
What binutils version?  Locally built, patched, RPMs?
I have never have trouble with objcopy since the pre-BFD days of binutils.
And that was a LONG time ago.
--joel
Stan wrote:
> Hello,
> I try to make a prom image;
> can you help me ?
> after make,
> m68k-rtems-size : text=47984 data=2208 bss=14512 dec=64704 hex=fcc0
> and,
> m68k-rtems-objcopy: warning :
> --change-section-vma .data = 0x00000000 never used
> --change-section-lma .data = 0x00000000 never used
> Can you tell me if linkcmd and hello.num are good ?
> Thank's.
> LINKCMDS.GZ
> Content-Type:
> application/x-gzip
> Content-Encoding:
> base64
> hello.num.gz
> Content-Type:
> application/x-gzip
> Content-Encoding:
> base64
