[rtai] RTEMS RTAI module
Erwin Rol
Erwin.Rol at Q-Soft-Engineering.com
Mon Sep 3 10:53:40 UTC 2001
Bernhard Kuhn wrote:
> Ralf Corsepius schrieb:
> > At least bochs is not dead, yet :) (cf.http://bochs.sourceforge.net)
> Thanks very much for that pointer!
> I just recognized that there exists a gdb-like
> command line debugger and a graphical debugger
> interface (http://www.qzx.com/bfe/).
A (long) while back i hacked Bochs to send the I/O of
a (bochs) serial port to a network socket. So than it is possible
to remote debug a application running on bochs with gdb.
I think the sources are still somewhere on the RTEMS ftp site,
they surely are old but migth still be usefull.
- Erwin
> Additionaly, you can do "Cosimulation". As far as i
> understood, you can i.e. emulate your external
> real time hardware with it.
> Also interessting: Bochs provides SMP with
> local APIC and I/O APIC emulation. This could
> make debugging of the RTAI SMP scheduler much
> easier.
> Sounds that Bochs is what Joel is looking for :-)
> best regards
> Bernhard
> Bernhard Kuhn, Software Engineer, Lineo Inc. (Where Open Meets Smart)
