termios and raw data - bug?
jennifer averett jennifer.averett at oarcorp.com
Wed Sep 19 21:21:22 UTC 2001
If I remember correctly the code used to be
  return (unsigned char)((*getReg)(pNS16550, NS16550_RECEIVE_BUFFER));
But this did not work correctly for the last board I used it on.  If the status line indicated
that there was no data available I read garbage out of the register.  I now have
the code looking as below.  Would it work to change cChar from a char to an unsigned char?
Jennifer
  unsigned32           pNS16550;
  unsigned char        ucLineStatus;
  char                      cChar;
  getRegister_f        getReg;
  pNS16550 = Console_Port_Tbl[minor].ulCtrlPort1;
  getReg   = Console_Port_Tbl[minor].getRegister;
  ucLineStatus = (*getReg)(pNS16550, NS16550_LINE_STATUS);
  if(ucLineStatus & SP_LSR_RDY) {
    cChar = (*getReg)(pNS16550, NS16550_RECEIVE_BUFFER);
    return (int)cChar;
  } else {
    return -1;
Joel Sherrill wrote:
> peter.o.mueller at gmx.de wrote:
> > > That seems a little complicated.  Would not
> > > work properly?
> > Who takes care about the changes. Joel, do you patch the serial driver code?
> I know I care and suspect that others care as well. :)
> In this type of case, I fall to my virtual knees and beg you to fix it
> in the BSPs you can test and make a stab at the others.  This is what I
> have had to do many times when a change impacts every BSP.  Just be
> careful.
> I will merge a patch.
> > Peter
> > GMX - Die Kommunikationsplattform im Internet.
> > http://www.gmx.net
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
