information about resources of actual application
Joel Sherrill joel at OARcorp.com
Fri Sep 28 00:13:19 UTC 2001
Aaron J. Grier wrote:
> On Thu, Sep 27, 2001 at 03:08:25PM +0200, Jan.Suchotzki at de.abb.com wrote:
>> I recognised, that the right version (which makes some output) of
>> malloc_dump() will be called only if RTEMS_DEBUG is defined.  I have
>> compiled and installed my Snapshot with VARIANT=DEBUG and compile my
>> appilcation with make debug. I´ve included rtems/libcsupport.h for
>> malloc_dump().
>> Can somebody tell me why it didn´t work? I try to execute it with the
>> m68k-efi332 bsp.
> when compiling RTEMS you need to add XCPPFLAGS=-DRTEMS_DEBUG, like so:
> make VARIANT=debug XCPPFLAGS=-DRTEMS_DEBUG
> VARIANT and XCPPFLAGS options are orthogonal.
Did you mean all caps DEBUG?
