how can i build the rtems multiprocess demos?
Sat Apr 6 15:28:11 UTC 2002
>   I can'nt build the multiprocessing demo,through i run configure and build scripts under linux
> like this:
>      ../rtems/./configure --target=i386-rtems --enable-mutliprocessing  --enable-test
#1.  --enable-multiprocessing is spelled incorrectly. :)
>      make RTEMS_BSP="pc386" install
>      When it finished,the other demos is ok.except the the mptests demos.
>      How can i build the multiprocessing demos???
#2.  RTEMS multiprocessing requires some BSP specific drivers to enable
communications between the processors.  This has never been implemented
for SMP-PCs.
But the tests should build but (I think) fail to link if you spelled
the option right.
>     Any advice are welcome.
