Blown stack ?
Puro Markku markku.puro at insta.fi
Wed Apr 10 13:40:42 UTC 2002
Unfortunately no,
problems appears with rtems-ss-20010816 and in early state of BSP
modifications.
I've change to use RTEMS-4.5.1-pre3 on that Intel evaluation board
but I still use "CPU_STACK_MINIMUM_SIZE (4*1024)" definition.
I accept that, although it sounds quite large.
( Perhaps I try to reduce 'stack minimum size' back to 1024 )
Joel: Is that 4096 for 'stack minimum size' too much for i386 ?
Iam running RTEMS-4.5.1-pre3 on Intel ev386ex card with interrupt driven
console
device at 38400 baud. CPU_STACK_MINIMUM_SIZE defined 4*1024.
I use ev_386ex BSP which based on i386ex BSP(biggest modifications in
start.S/start_ram.S, bsp_specs and linkcmds/linkcmds.ram).
So far it has been working without any major problems.
   -Mp
> -----Original Message-----
> From: Angelo Fraietta [mailto:angelo_f at bigpond.com]
> Sent: 10. huhtikuuta 2002 8:40
> To: Puro Markku
> Cc: 'rtems-users at oarcorp.com'
> Subject: Re: Blown stack ?
> Did this ever get sorted out? I am having a similar problem and I
> believe that it is also a stack problem.
> The reason I come to this conclusion is that when I add a
> cout function,
> even when the function cannot be called (this is because I have a
> volatile value set at false at this time), I get  similar sorts of
> exceptions. Just the existence of the added code within the function
> causes the failure.
> Puro Markku wrote:
> >Hi,
> >On ev386ex BSP(~i386ex) I ran into problems that looks like
> >stack overrun.  Anyhow I 'manage to fix' those by modifying
> >stack minimum size (original value was 1024) in
> >.../rtems-ss-20010816/c/src/exec/score/cpu/i386/rtems/score/cpu.h
> >( thats not the best place to do it but... ;)
> >--8<--------------------------------------------------------------
> > *  Minimum size of a thread's stack.
> >#define CPU_STACK_MINIMUM_SIZE           (4*1024)
> >Where can I define new value for (CPU_)STACK_MINIMUM_SIZE ?
> >Has anyone findout similar problems in startup ?
> >(pc386 works with default values. maybe its not a stack
> problem at all ? )
> >  -Mp
> >examples-4.5.0:
> >termios with default stack=1024
> >Initialized console on port COM2 9600-8-N-1
> >*** TEST OF TERMIOS INPUT CAPABILITIES ***
> >You----------------------------------------------------------
> >Exception 13 caught at PC 33E4 by thread 134283265
> >Processor execution context at time of the fault was  :
> > EAX = 1F       EBX = 1F        ECX = FD930     EDX = 3212
> > ESI = FB4B8    EDI = 361C      EBP = FCCC8     ESP = FCC8C
> >Error code pushed by processor itself (if not 0) = C1C0
> > ************ FAULTY THREAD WILL BE DELETED **************
> >after defining STACK_CHECKER_ON in
> >.../rtems-ss-20010816/c/src/lib/libbsp/i386/ev386ex/include/bsp.h
> >and CPU_STACK_MINIMUM_SIZE (2*1024) termios runs OK
> >but monitor generate BLOWN STACK.
> >*** MONITOR TASK TEST ***
> >Monitor ready, press enter to login.
> >BLOWN STACK!!! Offending task(0xfdb0c): id=0x08010007;
> name=0x524d4f4e
> >  stack covers range 0x000f0d7c - 0x000f157b (2048 bytes)
> >after defining CPU_STACK_MINIMUM_SIZE (4*1024) 'monitor' runs OK
> >Markku Puro           markku.puro at insta.fi
> Sarankulmankatu 20
> >                      tel.   +358 3  2659 769       FIN-33900 Tampere
> >INSTRUMENTOINTI OY    mobile +358 40 7092 769
> http://www.insta.fi
> >C3i Systems           fax    +358 3  2659 501
> Angelo Fraietta
> PO Box 859
> Hamilton NSW 2303
> Home Page
> http://www.users.bigpond.com/angelo_f/
> There are those who seek knowledge for the sake of knowledge
> - that is CURIOSITY
> There are those who seek knowledge to be known by others -
> that is VANITY
> There are those who seek knowledge in order to serve - that is LOVE
>     Bernard of Clairvaux (1090 - 1153)
