GNAT/RTEMS with i386 target problems - please help !
Sergio Jesus
srg_j at newmail.net
Fri Apr 19 05:08:14 UTC 2002
I cant help you.
I never succeeded building GNAT/RTEMS.
I think that PC386 BSP uses ELF and that GCC 2.8.1 requires COFF format, or
something like that...
Sorry :(
----- Original Message -----
To: <srg_j at newmail.net>
Sent: Wednesday, April 17, 2002 3:36 PM
Subject: GNAT/RTEMS with i386 target problems - please help !
> Hi Sergio,
> I'm new in a RTEMS. I'm trying to build GNAT/RTEMS on RH 7.2 Linux with
> i386 target, but with same problems as you (in
> RTEMS users mailist archive :
http://www.oarcorp.com/rtems/maillistArchives/rtems-users/2001/may/msg00068
> .html ).
> I'm fix this error with adding path 'include' to symbolic link generation
> procedure 'make_one_three' in file 'common.sh'.
> But occur the new problem :
> gcc -c -DCROSS_COMPILE -DIN_GCC -O2 -DHAVE_CONFIG_H -I.
> -I../../src/gcc -I../../src/gcc/config ../../src/gcc/bc-emit.c
> In file included from ../../src/gcc/bc-emit.c:982:
> ../../src/gcc/bc-typecd.def: In function `bc_emit_instruction':
> ../../src/gcc/bc-typecd.def:17: `SFtype' is promoted to `double' when
> passed through `...'
> ../../src/gcc/bc-typecd.def:17: (so you should pass `double' not `SFtype'
> to `va_arg')
> gmake[1]: *** [bc-emit.o] Error 1
> gmake[1]: Leaving directory `/rtems/tools/build-i386-tools/gcc'
> gmake: *** [all-gcc] Error 2
> My configuration :
> binutils-2.10 + binutils-2.10-rtems-gnat-3.13p-20001107.diff
> gcc-2.8.1 + gcc-2.8.1-rtems-gnat-3.13p-20000129.diff
> gnat-3.13p + gnat-3.13p-rtems-20000829.diff
> newlib-1.8.2 + newlib-1.8.2-rtems-20000606.diff
> ada_build_scripts-4.5.0.gz from
> ftp://ftp.oarcorp.com/pub/rtems/releases/4.5.0/ada_tools/source/
> Have you any result to this problem ? Are you successful with i386
> GNAT/RTEMS ?
> Thanks for a help,
> Miro Michalec, Ipesoft Ltd., Slovakia.
