htdig was Re: Power awareness
Jeff Mayes jeff.mayes at OARcorp.com
Mon Apr 22 18:59:35 UTC 2002
Sorry, this slipped through the cracks.  I thought momentarily
that htdig was on the other machine.  I have started building
the indexes so it should be back online by this evening at worst.
Again, sorry for any inconveniences.
Jeff
Joel Sherrill wrote:
> Jeff.. it looks like there is an htdig problem since
> upgrading www.  COuld you look into it please?
> Thanks.
> --joel
> Bill Butler wrote:
> > Joel,
> > I have tried for the past 2 days to use the user list archive search
> > engine and get a failure message when searching (Internal Server Error).
> > I have tried it under Explorer/2000 and Netscape/linux with the same
> > results.
> > Is it something on my end or Oarcorp?
> > Thanks
> > Bill Butler
> > AIPCom Inc
> > 972-644-2328 x16
> > bbill at tnex.com
> > -----Original Message-----
> > From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> > Sent: Friday, April 19, 2002 6:33 AM
> > To: Harvey Tuch
> > Cc: rtems-users at oarcorp.com
> > Subject: Re: Power awareness
> > Harvey Tuch wrote:
> > > Hi,
> > > I was wondering if anyone has done any work on power
> > awareness/management/
> > > efficiency on RTEMS (e.g. dynamic voltage scheduling, accounting, API
> > issues)? I
> > > gather some has been done on eCos, but I haven't seen anything on
> > RTEMS.
> > > I'm looking for an area to do a thesis at the moment, and I am
> > considering
> > > doing this, but I do not wish to duplicate existing work.
> > There is no variable power management capability right now but there is
> > a place to insert a switch to idle/low power mode.  Some CPUs and BSPs
> > have a special version of the IDLE task which puts the CPU in a low
> > power
> > state.  But there is nothing that says we are only 10% CPU utilization
> > so
> > lower the clock rate.
> > > Thanks,
> > > Harvey
> > > Harvey Tuch
> > htuch at cse.unsw.edu.au
> > Joel Sherrill, Ph.D.             Director of Research & Development
> > joel at OARcorp.com                 On-Line Applications Research
> > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >    Support Available             (256) 722-9985
