reentrant resolver
Tue Apr 23 00:58:25 UTC 2002
"Vyacheslav V. Burdjanadze" wrote:
> Is there some thread/task-safe DNS resolver intended to use with RTEMS?
> I tried to use that one which
> comes with libnetworking but it seemed to use select()/poll() and uses
> static buffers to decode NS replies.
Without looking at the code, I only see two easy possibilities:
  + protect it with a mutex
  + add a _r version of the function that takes a working
    buffer as an argument and make the existing function
    a wrapper that declares the needed buffer.
> Thanks.
> - " Why do you call this software 'beta' ? "
> - " Cuz it beta than nothin' ! "
