Netdemo examples Working on i386
Bill Butler
billb at tnex.com
Wed Apr 24 13:42:40 UTC 2002
All,
I thought I would update everyone that I have the netdemo working with
the i386/pc486 bsp.
I moved to the latest snapshot (20020301) and updated my tools. Now the
demo complained about a NE2000 timeout. After some more searching I
discovered this was because I had the wrong IRQ on the NIC card.
I could not really find any utilities I thought I was stuck. Luckily,
Win95 was installed on this 486 machine I was using and when I tried to
install the nic card It showed me the setting (irq3,0x300). Changing
this got me up and running.
So in summary, if you want to used a ne2000 nic card with netdemo you
need to
1) Set to your card type in bsp.h. All supported cards are listed now
#define BSP_NE2000_NETWORK_DRIVER_NAME
#define BSP_NE2000_NETWORK_DRIVER_ATTACH
2) Add number of File handle to something more reasonable in init.c
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS (30)
3) Set your IRQ on your nic card to 5 or modify the netdriver_config
structure in netconfigure.h for the demo code the following to the
static struct rtems_bsdnet_ifconfig netdriver_config = {
RTEMS_BSP_NETWORK_DRIVER_NAME, /* name */
RTEMS_BSP_NETWORK_DRIVER_ATTACH, /* attach function */
#ifdef RTEMS_USE_LOOPBACK
&loopback_config, /* link to next interface */
#else
NULL, /* No more interfaces */
#endif
#if (defined (RTEMS_USE_BOOTP))
NULL, /* BOOTP supplies IP address */
NULL, /* BOOTP supplies IP net mask */
#else
"192.168.1.26", /* IP address */
"255.255.255.0", /* IP net mask */
#endif /* !RTEMS_USE_BOOTP */
#if (defined (RTEMS_SET_ETHERNET_ADDRESS))
ethernet_address, /* Ethernet hardware address */
#else
NULL, /* Driver supplies hardware address
#endif
/* configure the IRQ in this section 0 = default*/
0, /* ignore_broadcast */
0, /* mtu */
0, /* rbuf_count */
0, /* xbuf_count*/
0, /* port use default of 0x300 */
3, /* irno */
0, /* bpar*/
Hope that helps
PS. I believe that the 4.5.0 version would have worked fine if I had the
IRQ set correctly. It's just that the newer version of the driver gave
an error message that Interrupts weren't working!
Bill Butler
AIPCom Inc
972-644-2328 x16
bbill at tnex.com
> -----Original Message-----
> From: Bill Butler [mailto:billb at tnex.com]
> Sent: Monday, April 22, 2002 10:05 AM
> To: 'Eric Norum'
> Cc: 'rtems-users at oarcorp.com'
> Subject: RE: Netdemo examples.
> > From: Eric Norum [mailto:eric.norum at usask.ca]
> > On Monday, April 22, 2002, at 08:06 AM, Bill Butler wrote:
> > > I bet this has been answered before but I still can not get the
> > > search to work and have searched back to last april with now
luck..
> > > I have the Netdemo4-5.0/netdemo up and working for the most part
on a
> > > i386/PC486 BSP. I using the 4.5.0 release (no snapshots). I can
get
> the
> > > demo to come up and request and receive an IP using BOOTP when in
> BootP
> > > mode. It displays no errors and is able to create, bind, listen,
> accept
> > > sockets.
> > > The "u" test seems to work but "t" or tcp/ip test times out --
Giving
> > > "Can't connect socket: Connection timed out".
> > > I have also tried to hardcode its IP with the same results.
> > Is the TCP`discard' socket active on the machine you're trying to
> > connect to from the RTEMS machine?
> Unsure.. I need to look into this since I'm not really familiar with
> Discard socket. I have tried both uncommenting the 127.0.0.0 and
setting
> it to the machine I'm trying to use telnet on. (ie 192.168.1.11- my
linux
> box)
> > > Trying to ping the pc running Rtems/netdemo times out and trying
to
> > > connect using telnet 192.168.1.16 24742 does not work as
advertised.
> > > To me this sounds like a TCP/IP problem more than the demo problem
and
> I
> > > am hesitant to move on with development until I get this demo
working.
> > Is the RTEMS machine configured to accept broadcast packets?
> > Can you run a packet sniffer and see exactly what's happening on
your
> > network?
> I have not changed anything on the demo except to enable BootP and add
> more files handles. When I use the sniffer It does not look to me that
the
> Rtems box tries to except the telnet session. But I need to look into
this
> more but I really thought the netDemo should work pretty much as is.
> Thanks
> Bill
