device driver code that can response to SEEK_END
Pattara Kiatisevi
pkiatisevi at student.ei.uni-stuttgart.de
Wed Apr 24 14:26:36 UTC 2002
Hi all,
I still have problem with this seeking problem with my device driver code.
I found it has problem when there is a call fseek(x,0,SEEK_END). Anybody
has idea how should i write the device driver code to let this SEEK_END
work. I mean how should I update these variables:
typedef struct {
rtems_libio_t *iop;
off_t offset;
unsigned8 *buffer;
unsigned32 count;
unsigned32 flags;
unsigned32 bytes_moved;
} rtems_libio_rw_args_t;
So far I just check if offset > mydatasize then return with bytes_moved =
0;
Thank you very much,
Pattara
Please avoid sending me Word or PowerPoint attachments.
See http://www.fsf.org/philosophy/no-word-attachments.html
Ott Pattara Kiatisevi T L W G
M.Sc. INFOTECH Student, Stuttgart, Germany http://linux.thai.net/
