ARM interrupt handling
Jay Monkman jtm at smoothsmoothie.com
Thu Apr 25 17:46:08 UTC 2002
On Thu, Apr 25, 2002 at 07:18:50AM -0500, Joel Sherrill wrote:
> Jay.. if you confirm this is OK, I will merge it.
It seems to work if I comment out this line:
   #define SAVE_CPSR
in exec/score/cpu/arm/cpu_asm.S.
At least the ticker sample works. A few of the sp tests fail,
specifically
	sp04 - hangs after this output:
		TA1 - rtems_task_suspend - on Task 2
		TA1 - rtems_task_suspend - on Task 3
		TA1 - killing time
		TA1 - rtems_task_resume - on Task 2
		TA1 - rtems_task_resume - on Task 3
	sp30 - times are off by 5 seconds
		ta1 runs with 10 sec interval rather than 5
		ta2 runs with 15 sec interval rather than 10
		ta3 runs with 20 sec interval rather than 15
	sp31 - I get this output:
		INIT - rtems_timer_create - creating timer 1
		INIT - timer 1 has id (0x14010001)
		INIT - rtems_timer_create - creating timer 2
		INIT - timer 2 has id (0x14010002)
		TA1 - rtems_timer_ident - identing timer 1
		TA1 - timer 1 has id (0x14010001)
		TA1 - rtems_timer_ident - identing timer 2
		TA1 - timer 2 has id (0x14010002)
		TA1 - rtems_timer_server_fire_after - timer 1 in 30 seconds
		TA1 - rtems_timer_server_fire_after - timer 2 in 60 seconds
		Timer 1 scheduled for 3084 ticks since boot
		Timer Server scheduled for 3039 ticks since boot
		TA1 - rtems_task_wake_after - 1 second
		assertion "(info.start_time + info.initial) == (_Timer_Server->Timer.initial + _Timer_Server->Timer.start_time)" failed: file "../../../../../../../../cvs-rtems/kernel/c/src/tests/sptests/sp31/task1.c", line 78
I haven't look at these in detail yet, so if you have any ideas where
to look, I'd appreciate the help.
Jay Monkman	    The truth knocks on the door and you say "Go away, I'm
monkman at jump.net    looking for the truth," and so it goes away. Puzzling.
		     - from _Zen_and_the_Art_of_Motorcycle_Maintenance_
