ARM interrupt handling
Jay Monkman jtm at smoothsmoothie.com
Thu Apr 25 18:26:16 UTC 2002
On Thu, Apr 25, 2002 at 12:50:37PM -0500, Joel Sherrill wrote:
> Does the time passage in sp01 look close to correct?
Yes.
> My recommendation is to use a simulator like sparc/erc32
> or powerpc/psim and trace through a working one.  Then
> compare the behavior.  It is really handy when trying to
> see what is happening in the same source base.
I'll try that.
> Do all the other tests run?  It is always possible that
> sp04 was randomly broken in the snapshot you are running.
> That is why the simulator is so useful.  Besides you can
> download the gcc, binutils, and gdb w/sim as RPMs in
> minutes and have some confidence.
The other tests do run, but I didn't verify all of the
output. I just checked to see if they finished, and if they
looked approximately correct. I just wanted a quick check.
I'll run them again later, and check the output thoroughly.
> Hmmm... are you running polled console IO?  That would explain
> some time skewing but not sp04.
Yes.
Thanks for the help.
Jay Monkman	    The truth knocks on the door and you say "Go away, I'm
monkman at jump.net    looking for the truth," and so it goes away. Puzzling.
		     - from _Zen_and_the_Art_of_Motorcycle_Maintenance_
