gcc 3.1 i386 testing request
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Apr 25 20:59:01 UTC 2002
Hi,
Eric Norum was testing gcc 3.1 preview tarballs on the i386
and we think he may have discovered a bad problem and we
need volunteers to help confirm this. You would need to
have an i386 target with networking and be willing to
build a gcc 3.1 preview toolset. Then use that toolset
to build RTEMS with networking and see if it works.
>From Eric Norum...
Does this happen for you, too? I'd like to know that I'm not chasing a
ghost. The symptoms, when running the netdemo program are that you can
ping the RTEMS target, but you can't telnet to it. You can also see the
problem if you run a packet sniffer and type a `u' to the netdemo
program console -- you'll see a bunch of UDP packets from the RTEMS
machine, all with bad IP checksums :-(
As best we can tell, gcc 3.1 previews may be generating incorrect
code for the optimized i386 in_cksum routines.
We are trying not to be alarmist and need help in confirming this
and tracking it down. If this is a real problem in gcc, then it
would potentially impact any x86 target. So we want to be sure
about the problem, file a good report, and try to get it fixed.
Eric.. didn't you have a framework at one point that ran both
the optimized and unoptimized versions outside the source tree
to compare their results? Installing the native GNU/Linux x86
3.1 compiler and running that might be a quick doublecheck.
joel at OARcorp.com On-Line Applications Research
