problem cross compiling rtems
Jack Cawkwell J.Cawkwell at open.ac.uk
Fri Apr 26 06:52:12 UTC 2002
Hi,
I am trying to cross compile rtems (under Linux on i386)
so that I can run it under gdb. But I get problems
with time.h, something like parse error before clock_id
and timer)id. I did some investigating, but it the
typedef seems to be defined, at least for some paths thru
the compilation.
I must be doing something wrong, I started with m68k
and then tried powerPC, but go the same problem?
Jack
