problem cross compiling rtems
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Apr 26 09:17:21 UTC 2002
Am Fre, 2002-04-26 um 08.52 schrieb Jack Cawkwell:
> Hi,
> I am trying to cross compile rtems (under Linux on i386)
> so that I can run it under gdb. But I get problems
> with time.h, something like parse error before clock_id
> and timer)id. I did some investigating, but it the
> typedef seems to be defined, at least for some paths thru
> the compilation.
Please send the full error message with a detailed description of what
you did to this list (configuration options, which file etc.).
Ralf
