Problems installing gdb-bdm
Chris Johns cjohns at cybertec.com.au
Mon Apr 29 14:45:26 UTC 2002
> Claudio Imberlina wrote:
> Hello,
>  I was trying to install gdb-bdm and gdb-5.0. I have problem
> installing =
> gdb-5.0, after patching with gdb-bdm, the make file complain for a =
> directory "BDM" ( -lBDM ), and cannot complete the installation.
What host are you using ?
> When I installed gdb-bdm ( I am using an ICD cable ), during the =
> installation everything was OK, but when I try to check the driver as
> root with ./chk /dev/bdmicd1 ( on LPT2 ) it complain about BDM not
> open, =
> when I use /dev/bdmcpu321, it comunicate with the board but it can not
> test the registers and storp after D00, an emit a message like =
> debugFlag.
> Any Idea, I will apreciate very much your help
What CPU are you debugging ?
 Chris Johns, cjohns at cybertec.com.au
