[oggonachip] Re: posix platform and pthread
Ralf Corsepius corsepiu at faw.uni-ulm.de
Mon Apr 29 16:05:42 UTC 2002
Am Mon, 2002-04-29 um 17.49 schrieb Pattara Kiatisevi:
> opps, I am using gcc:
> gcc -B/usr/local/ott-rtems/posix/lib/ -specs bsp_specs -qrtems -o test-x86
> test.c soundinput.c
> so this is wrong? I have also installed i386-rtems-gcc (debs from OAR's
> ftp) but couldn't get it compiled yet (I don't know what options for
> compiler to be used).
Just to clarify: Are you trying to build the posix-BSP or are you trying
to use pthreads on a pc386-BSP?
As far as I understood your question, your are trying to use pthreads
with the unix/posix BSP.
This is not supported by the posix-BSP (the unix/posix-BSP does not
support pthreads/rtems's posix-thread implementation.
Ralf
