Problems installing gdb-bdm
Mike Panetta ahuitzot at mindspring.com
Tue Apr 30 01:00:36 UTC 2002
On Mon, 2002-04-29 at 17:37, Claudio Imberlina wrote:
[snip]
> When I test the driver with : ./chk /dev/bdmcpu321 this is the result
Try using the -D (I think thats it) delay option.  Set it to something like 1000 and if that works, back down untill it stops working and then add say 50%.
> Driver Ver :    2.8
> Procesor :    CPU32
> Interface :    Eric's CPU32
> Target status :   0x4    -- NOT RESET, NOT HALTED, STOPPED, POWER ON, CONNECTED
> Register test,    1 of 1 :
> D00 :
> Write Register failed : Invalid target command
> When I try with : ./chk /dev/bdmicd1, the result is
> open failed : BDM not open
>   ----- Original Message -----
>   From: Eric Norum
>   To: Claudio Imberlina
>   Cc: rtems-users at oarcorp.com
>   Sent: Monday, April 29, 2002 10:40 AM
>   Subject: Re: Problems installing gdb-bdm
