multiprocessor boot
Francesco Poletti
fpoletti at libero.it
Mon Dec 2 15:54:43 UTC 2002
Tanks to Joel for the first answer, I really appreciate the helps which
you give me!
Another question which I have is, How does RTEMS require to be booted on
an multiprocessor system?
Are the boot on every processor indipendent?
How does the global object initialization is made?
Thanks to all Francesco
> Francesco Poletti wrote:
> > Hy, I'm reading the multiprocessor's doc and I have these two simple
> > question:
> > -When a task use a global object which don't reside on its
processor,
> > RTEMS "calls" the MPCI layer for have the object from another
processor.
> > Those passages are used every time that task make operation over the
> > global object?
> When the object resides on a remote node, yes. If the object is
> global and a task residing on the same node uses that object, then
> the object is considered local and goes through the normal path.
> > -Is possible, for a task, sending an "event" or a signal to another
> > task which is global but don't reside on same processor? If yes in
this
> > case an RQ (which need answer) or an RP wich don't block the first
task?
> Both those are RQ type since the caller needs a status on the
event_send
> or signal_send service call.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
