Router type features in RTEMS TCP/IP stack
Charles Steaderman charlies at poliac.com
Thu Dec 5 20:52:50 UTC 2002
Are you implying, then, that NAT/Masquerading, IPForwarding, IPFW, etc
will be part of the porting effort or are those services "attached" to
the IP data chain as separate processes which will require additional
porting efforts?
- Charlie
Eric Norum wrote:
> On Thursday, December 5, 2002, at 10:38  AM, Charles Steaderman wrote:
>> Does the RTEMS TCP/IP stack support router device features such as
>> NAT/Masquerading, IPForwarding, IPFW (for IPSec forwarding)? If not,
>> what would involved in porting these services from a current ***BSD?
> I plan on releasing a new BSD stack as soon as there's a stable
> release of RTEMS to base it on.  I will port the full termios code
> from BSD, too -- get ready to rewrite all your terminal I/O device
> handlers.
Charlie Steaderman
VP Engineering
Poliac Research Corporation
Phone: 952.707.6245
Cel: 612.242.6364
