MIPS GNAT/RTEMS success!!
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Fri Dec 6 00:37:50 UTC 2002
gregory.menke at gsfc.nasa.gov wrote:
> Joel Sherrill writes:
>  > Hi,
>  > Just a note to let everyone know that I successfully ran the
>  > Ada RTEMS hello world program on the MIPS target using the
>  > jmr3904 simulator!!!  YEAH!!
>  > I also successfully built for the pc386.
>  > This is using gcc 3.2.1 and the soon to be avaiable RPMs.
> Yay!
> I'll also add that I got INIT_FINI for static C++ constructors working
> on the jmr3904, tested via my own apps and hello.exe.  I'll try it on
> the Mongoose tomorrow.  The jmr3904 C++ issues were lack of the
> crtbegin/end stuff in the bsp_specs and a somewhat old linkcmds.  I
> think this update could likely be extended to all the MIPS bsp's.
> I did a similar C++ constructor support update to the shared motorola
> bsp's, so far they are testing out OK.
And a big YEAH to you also. :)  I look forward to these patches.
> Gregm
