non-maskable interrupt
    Ilya Alexeev
    ilya at continuum.ru
    Fri Dec  6 12:41:53 UTC 2002
Hi all.
I am using rtems-ss-20020301 and gen68360 bsp.
My MC68360 board has external device which uses
non-maskable Level 7 Interrupt Autovector.
RTEMS documentation says that it is OK to use non-maskable ISRs,
but they are must not use system calls.
My ISR doen't use any system calls,
it just read/write a registers of external device,
but there are some problems then this ISR called too often.
This ISR spoils some RTEMS internal data structures.
I have add a number of test tasks for my application,
which are just call rtems_task_wake_after(1).
Then I call the ISR enough often,
my system hangs somewhere in RTEMS' _Watchdog* routines...
What I am doing wrong?
Is it possible to correctly use non-maskable ISR in RTEMS?
And one more thing - I am using standart call - rtems_interrupt_catch
for attaching non-maskable ISR.. Is it OK?
I will be grateful for any help.
Ilya V. Alexeev
Continuum Plus JSC
Yaroslavl, Russia
Phone: (+7)0852 240200
Fax:   (+7)0852 359977
