The Great Watchdog Hack
Chris Johns cjohns at cybertec.com.au
Mon Dec 9 01:00:36 UTC 2002
Joel Sherrill wrote:
> Paul Evans wrote:>
> >This isn't working, so I'm wondering where RTEMS is spending it's time
> >during power up. Any ideas?
> Zero'ing the workspace could be a huge consumer of time.  This can be
> disabled by the BSP via the do_zero_of_workspace of the CPU
> Configuration Table.
Are you sure this is ok ?
When I was checking the IDLE code for changes in the printing of the IDLE label by
the monitor I noticed a comment in cpukit/score/src/threadcreateidle.c:
    *  The entire workspace is zeroed during its initialization.  Thus, all
    *  fields not explicitly assigned were explicitly zeroed by
    *  _Workspace_Initialization.
   _Thread_Idle = _Thread_Internal_allocate();
Could this cause problems if the workspace is not initialised ?
> You could also hook each of the initialization user extension points
> and reset it.
.. or have the timer interrupt contain a counter that is decremented until 0 and
while not zero it hits the watchdog. Set the counter to be long enough to allow the
initialisation to complete.
  Chris Johns, cjohns at cybertec.com.au
