multiprocessor architecture...2
Francesco Poletti fpoletti at libero.it
Wed Dec 11 16:10:09 UTC 2002
Sorry Joel, I was looking for some architecture suggestion: my simulator
is under development and I don't know which is best way to implement the
mechanism by which a processore may be able to interrupt another. I
don't know which are architectural possibility...If anyone may suggest
me where I can find documentation.
Francesco
> Francesco Poletti wrote:
> > Hy, I'm developing a multi arm simulator which one day... will be
boot
> > with rtems.
> > When I read the shared memory code I saw that may be important for
the
> > comunication between processor which one node will able to interrupt
> > another node. In my simulator this thing isn't implemented and I'm
> > asking which way may be more coorect...I'm looking for documentation
but
> > I don't find anything interesting.
> Not surprising as this is a shared memory driver specific question.
> It supports using either interrupts between the boards or installing a
> routine that is called on each clock tick to poll for new packets.
> This is configurable on a per BSP basis via the shmconfig support.
> [NOTE: The shared memory driver predates the Classic API timer
> manager.  It really should use the timer manager for its polling
> routine instead of the clock tick trick it is currently using.]
> > Thanks to anyone which can help me.
> > Francesco.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
> Support Available                (256) 722-9985
