multiprocessor architecture...3
Wed Dec 11 18:08:19 UTC 2002
Francesco Poletti wrote:
> Yes is properly that, the pool vay I think may be a first implementation
> but after I need to improve my simulator like this I need to understand
> better how the second two methods works...
OK.  Once you get that far and see how other things work on the
simulator,
ping me.  The key will be deciding what the "space" used between the
multiple CPUs looks like.  Once that is specified, you are in business.
NOTE: The powerpc psim BSP uses UNIX shared memory, UNIX semaphores
to protect access, and polling.  The UNIX shared memory is mapped into
processor address space.  If you go this route, then you should be able
to intermix psim with the other cpus in your system.
> Francesco
> > > Sorry Joel, I was looking for some architecture suggestion: my
> simulator
> > > is under development and I don't know which is best way to implement
> the
> > > mechanism by which a processore may be able to interrupt another. I
> > > don't know which are architectural possibility...If anyone may
> suggest
> > > me where I can find documentation.
> > Three possibilities I know of.. others probably exist:
> >  + poll
> >  + board feature for in inter-board interrupt.  I know the Motorola
> >    VME m68k boards tended to have this feature as did other vendors.
> >  + CPU feature.  The hppa had an interprocessor bus for SMP boards.
> >    Based upon the "node number" in the system (hardcoded), each
> >    CPU had some MP communications registers at a certain address.
> >    These included this type of interrupt.  This is the only CPU RTEMS
> >    has been ported to that I know has this type of feature.
> > Your simulator has to simulate a CPU and its external peripherals to
> > provide a complete -- if simple -- system.
> > Is that more what you were looking for?
> > > Francesco
> > > > > Hy, I'm developing a multi arm simulator which one day... will
> be
> > > boot
> > > > > with rtems.
> > > > > When I read the shared memory code I saw that may be important
> for
> > > the
> > > > > comunication between processor which one node will able to
> interrupt
> > > > > another node. In my simulator this thing isn't implemented and
> I'm
> > > > > asking which way may be more coorect...I'm looking for
> documentation
> > > but
> > > > > I don't find anything interesting.
> > > > Not surprising as this is a shared memory driver specific
> question.
> > > > It supports using either interrupts between the boards or
> installing a
> > > > routine that is called on each clock tick to poll for new packets.
> > > > This is configurable on a per BSP basis via the shmconfig support.
> > > > [NOTE: The shared memory driver predates the Classic API timer
> > > > manager.  It really should use the timer manager for its polling
> > > > routine instead of the clock tick trick it is currently using.]
> > > > > Thanks to anyone which can help me.
> > > > > Francesco.
> > > > Joel Sherrill, Ph.D.             Director of Research &
> Development
> > > > joel at OARcorp.com                 On-Line Applications Research
> > > > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> > > > Support Available                (256) 722-9985
> > Joel Sherrill, Ph.D.             Director of Research & Development
