NFS client for RTEMS released
Thu Dec 19 14:23:12 UTC 2002
Till Straumann wrote:
> I believe I have never 'officially' announced this:
YEAH!! Congratulations.
> Here
> http://www.slac.stanford.edu/~strauman/rtems/nfs/index.html
Is it OK to mirror your work into contrib on OAR's site?
> comes a trivial NFS V2 client implementation for
> RTEMS (no caching / read-ahead / delayed-write).
> The README available at the website should give
> comprehensive information.
> The NFS package can be used as a loadable module
> (use CEXP) or as a static library.
> Note that at the time of writing, the RTEMS filesystem
> implementation still contains a couple of bugs
> (see README) who need to be patched or worked around
> (PRs have been filed).
What PRs are these?  I have had a lot of deadlines in
November and December so may not have been getting to
them as fast as usual.  I thought Jennifer and I had
dealt with some filesystem PRs for you though.
> At this point, NFS is considered beta.
> NFS comes with standard RTEMS Makefiles, i.e. set
> the RTEMS_MAKEFILE_PATH environment variable and
> issue 'make'.
> Some system parameters may be tuned - consult the
> source.
> Looking forward to any feedback...
> -- Till
