Newbie RTEMs user's RTEMS build failing
jamesfit at paradise.net.nz
Thu Dec 19 21:29:21 UTC 2002
Hi all,
I am new to RTEMS and this is my first post to this list.
I have downloaded and successfully built (from source) the RTEMS toolchain on a
Mac OS X host (my development machine) for an m68k target.
I encountered a problem building RTEMS itself however. I am building the latest
snapshot and the mrm332 BSP. You can see the error below.
Thanks for any and all help you can provide,
regards,
James Fitzsimons
<snip>
Making all in src
make all-am
mkdir o-optimize
m68k-rtems-gcc --pipe -isystem ../../../../../mrm332/lib/include -
DHAVE_CONFIG_H -I. -D__RTEMS_INSIDE__ -ansi -fasm -O4 -fomit-frame-
pointer -g -O2 -mcpu32 -o o-optimize/adasupp.o -c ../../../../../../../rtems-
ss-20021118/c/src/../../cpukit/posix/src/adasupp.c
pointer -g -O2 -mcpu32 -o o-optimize/cancel.o -c ../../../../../../../rtems-ss-
20021118/c/src/../../cpukit/posix/src/cancel.c
pointer -g -O2 -mcpu32 -o o-optimize/cancelrun.o -c ../../../../../../../rtems-
ss-20021118/c/src/../../cpukit/posix/src/cancelrun.c
20021118/c/src/../../cpukit/posix/src/cancelrun.c: In function
`_POSIX_Threads_cancel_run':
20021118/c/src/../../cpukit/posix/src/cancelrun.c:55: `PTHREAD_CANCELED'
undeclared (first use in this function)
20021118/c/src/../../cpukit/posix/src/cancelrun.c:55: (Each undeclared
identifier is reported only once
20021118/c/src/../../cpukit/posix/src/cancelrun.c:55: for each function it
appears in.)
make[6]: *** [o-optimize/cancelrun.o] Error 1
make[5]: *** [all] Error 2
make[4]: *** [all-recursive] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
bash-2.05a$
</snip>
