Newbie RTEMs user's RTEMS build failing
jamesfit at paradise.net.nz jamesfit at paradise.net.nz
Thu Dec 19 22:13:35 UTC 2002
Hi Alan,
I am also using OS X 10.2.2. The target board I am building for the MRM
(http://www.robominds.com) has no network capability so I disabled that. I
enabled POSIX because I thought that that would provide a somewhat familiar
interface for me (UNIX, Linux background). I also disabled the ITRON interface
as I am not familiar with that. Other than those changes it was just the basic
build switches as specified in the "Getting started" doc.
Is the POSIX interface worth investigating? It seems from the documentation
that it is not a popular option?
Thanks again.
Regards,
James Fitzsimons
> James,
> I have successfully built the m68k-rtems toolchain and the 20021118
> RTEMS snapshot on Mac OS X 10.2.2 . What version of Mac OS X do you
> have?
> I am interested in the Coldfire processor, but when I first started, I
> think I built all of the m68k BSPs by default.
> What configuration options did you use?
> I might have disabled POSIX interfaces and it looks like you are getting
> errors on the posix interfaces?
> Alan Cudmore
