Newbie RTEMs user's RTEMS build failing
jamesfit at paradise.net.nz jamesfit at paradise.net.nz
Thu Dec 19 23:00:29 UTC 2002
Hi Joel,
Well it was probably just me reading to much into to little ;-) I just noticed
that all of the examples for building RTEMS in the "Getting Started with RTEMS
for C/C++ Users" (started.pdf) document have posix disabled. Also when I looked
at the POSIX documentation it looked like it either hadn't been updated for a
while or a lot of the functionality wasn't implemented in RTEMS.
As I said, probably me just jumping to conclusions on far too little evidence.
Anyhow, I plan to go play happily with the POSIX interface now that I know how
to get the build working.
Thanks all,
Regards,
James Fitzsimons
> I am sorry you got that impression from the documentation. Where
> is POSIX denigrated? The POSIX API tends to be the foundation for
> packages that are ported to RTEMS and a lot of people use it.
> I know that the GoAhead webserver, GNAT, NTPD, MDP, ACE/TAO, and most
> ports of GNU packages assume the POSIX API is enabled. The RTEMS
> POSIX API is about as complete as is technically possibly given
> that RTEMS does nto have memory protection and true processes.
> I would like to make sure the documentation does not mislead
> anyone about the POSIX API. I know the POSIX API wasn't that
> robust when it initially appeared in RTEMS so there may be some
> lurking comments from that many years ago.
> --joel
