bsp-wide #defines
gregory.menke at gsfc.nasa.gov
Sun Dec 29 03:26:09 UTC 2002
Hi Joel,
I posted this here in case you check the list instead of your work
email. I'm doing fairly well on the Racerxc bsp, its
configuring/makeing OK at this point. I do find I need to #define a
couple things for the bsp that apply to source under libcpu. I was
wondering if you prefer to put such things in bsp_specs or in the
CFLAGS supplied by the make/custom .cfg file.
Thanks,
Greg
