bsp-wide #defines
Sun Dec 29 16:29:27 UTC 2002
gregory.menke at gsfc.nasa.gov wrote:
> Hi Joel,
> I posted this here in case you check the list instead of your work
> email.  I'm doing fairly well on the Racerxc bsp, its
> configuring/makeing OK at this point.  I do find I need to #define a
> couple things for the bsp that apply to source under libcpu.  I was
> wondering if you prefer to put such things in bsp_specs or in the
> CFLAGS supplied by the make/custom .cfg file.
Neither :).  Ralf may comment differently but the appropriate place
is usually in bsp.h or bspopts.h.in.  bspopts.h can be changed
via BSP specific configure options so it might be desirable for
certain types of things like default BSP initialization (e.g.
console polled vs. interrupt).
> Thanks,
> Greg
