Strange Problem calling chdir()
Peter Mueller peter.o.mueller at gmx.de
Mon Dec 30 14:16:08 UTC 2002
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello all,
I have a strange problem with the code shown below. In dummyHMI::test()
argc/argv are in reality built from commands/parameters I get from a
serial line. The problem is that the name holds "test" as expected in
dummyClient::printdir(), but is empty in chdir().
The code works fine under native Linux. I'm working with
rtems-ss-20020628 and  m68k-rtems-gcc 2.95.3
Any ideas?
Thanks a lot,
Peter
class dummyClient{
public:
	void printdir(int argc, char* name){	// name zeigt noch den richtigen wert
("test")
		int res = chdir(name);	// in chdir ist name = ""
class dummyHMI{
public:
	dummyHMI::dummyHMI(dummyClient* in){
		m_client = in;
	void dir(int argc, char* argv[]){
		if(argc>1)
			m_client->printdir(argc, argv[1]);
	void test(void){
		char buffer[]="a.out\0test\0";
		char* myargv[10];
		int myargc=2;
		myargv[0]=buffer;
		myargv[1]=&buffer[6];
		dir(myargc, myargv);
	dummyClient* m_client;
Init(){
	dummyClient * aclient = new dummyClient;
	dummyHMI* hmi = new dummyHMI(aclient);
	hmi->test();
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.7 (GNU/Linux)
iD8DBQE+EFUoUzCcwYQMTJoRAoUsAJ9YwFqm7hRWQnqTlLjibVvmSeu8ZQCfYp6S
v1ZZo498Omx9aPiaQ1i5fdA=
=HwSv
-----END PGP SIGNATURE-----
