Does POSIX standard say EXPLICIT or IMPLICIT SCHED
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Wed Dec 4 16:37:17 UTC 2002
Am Mit, 2002-12-04 um 16.48 schrieb Joel Sherrill:
> > > My benchmark code fails to set PTHREAD_EXPLICIT_SCHED and hence
> > > the benchmark task runs at the wrong priority. I had developed the
> > > pthread stuff for RT-Linux (where EXPLICIT_SCHED is the default,
> > > as it is on some other systems, it seems).
> > I searched some last night
> and unfortunately did not complete this paragraph. :(
> I looked to see what the POSIX or OpenGroup standards say about this
> and didn't find anything which gave me a clue.
>From SUSV3/pthread_attr_init():
The pthread_attr_init() function shall initialize a thread attributes
object attr with the default value for all of the individual attributes
used by a given implementation.
I read this as being "explicitly unspecific", i.e. "everything is
implementation-defined".
> Does anyone out there
> know what The Right Thing To Do (TM) is?
IMO: "You must not rely on any implicit defaults".
Anyway, from Solaris-2.7's pthread_attr_init's man-page:
The pthread_attr_init() function initializes a thread attri-
butes object ( attr) with the default value for each attri-
bute as follows:
Attribute Default Value Meaning of Default
contentionscope PTHREAD_SCOPE_PROCESS resource competition within process
detachstate PTHREAD_CREATE_JOINABLE joinable by other threads
stackaddr NULL stack allocated by system
stacksize NULL 1 or 2 megabyte
priority 0 priority of the thread
policy SCHED_OTHER determined by system
inheritsched PTHREAD_EXPLICIT_SCHED scheduling policy and parameters
not inherited but explicitly
defined by the attribute object
guardsize PAGESIZE size of guard area for a thread's
created stack
Linux pthread_attr_init man-page
inheritsched
Indicate whether the scheduling policy and scheduling parameters for
the newly created thread are determined by the values of the schedpol-
icy and schedparam attributes (value PTHREAD_EXPLICIT_SCHED) or are
inherited from the parent thread (value PTHREAD_INHERIT_SCHED).
Default value: PTHREAD_EXPLICIT_SCHED.
Ralf
