Does POSIX standard say EXPLICIT or IMPLICIT SCHED
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Dec 4 18:00:39 UTC 2002
Ralf Corsepius wrote:
> Am Mit, 2002-12-04 um 18.18 schrieb Joel Sherrill:
> > Till Straumann wrote:
> > > I guess I was naive when I first wrote the benchmark code - I figured
> > > POSIX was a standard
> > > and hence the defaults would be standardized.
> > HAHAHAHA!!! :) The reason for this perception is that in general
> > things are portable.
> <*fg*> pthread_attr_setschedpolicy </*fg*>
> SUSV3 says "SCHED_OTHER, SCHED_RR and SCHED_FIFO shall ..."
> SCHED_OTHER is the default on most systems, but ..
> * what is SCHED_OTHER?
The user doesn't know. As you know it is unspecified and implementation
dependent. I assume it should be documented by the OS vendor. For
RTEMS, these variations impact the timeslicing of the individual
task/thread.
SCHED_OTHER - reset thread timeslice on each switch
SCHED_RR - exhaust timeslice before getting a new allotment
SCHED_FIFO - no timeslicing.
SCHED_OTHER in RTEMS is somewhat meaningful since it makes POSIX thread
timeslicing behave like timesliced Classic tasks. But it is certainly
not guaranteed to be like any other OS.
> * Some "POSIX-compliant" OSes do not provide SCHED_RR or SCHED_FIFO
I recall that they were new in 1003.1b -- not in 1003.1. So OSes that
have never really been updated to POSIX circa 1994 don't have them.
> * Some schedulers require special permission (eg. root) or system
> settings on some systems.
Linux for one is in this category. I have written code to ignore
the EPERM/EINVAL errors from Linux if you try to do a
pthread_setschedparam
for SCHED_RR. It is the same for SCHED_FIFO.
> Ralf
joel at OARcorp.com On-Line Applications Research
