Does POSIX standard say EXPLICIT or IMPLICIT SCHED
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Thu Dec 5 02:06:06 UTC 2002
Am Mit, 2002-12-04 um 19.00 schrieb Joel Sherrill:
> Ralf Corsepius wrote:
> > Am Mit, 2002-12-04 um 18.18 schrieb Joel Sherrill:
> > > Till Straumann wrote:
> > > > I guess I was naive when I first wrote the benchmark code - I figured
> > > > POSIX was a standard
> > > > and hence the defaults would be standardized.
> > > HAHAHAHA!!! :) The reason for this perception is that in general
> > > things are portable.
> > <*fg*> pthread_attr_setschedpolicy </*fg*>
> > SUSV3 says "SCHED_OTHER, SCHED_RR and SCHED_FIFO shall ..."
> > SCHED_OTHER is the default on most systems, but ..
> > * what is SCHED_OTHER?
> The user doesn't know. As you know it is unspecified and implementation
> dependent. I assume it should be documented by the OS vendor. For
> RTEMS, these variations impact the timeslicing of the individual
> task/thread.
> SCHED_OTHER - reset thread timeslice on each switch
> SCHED_RR - exhaust timeslice before getting a new allotment
> SCHED_FIFO - no timeslicing.
> SCHED_OTHER in RTEMS is somewhat meaningful since it makes POSIX thread
> timeslicing behave like timesliced Classic tasks. But it is certainly
> not guaranteed to be like any other OS.
> > * Some "POSIX-compliant" OSes do not provide SCHED_RR or SCHED_FIFO
> I recall that they were new in 1003.1b -- not in 1003.1. So OSes that
> have never really been updated to POSIX circa 1994 don't have them.
Well, not necessarily. Linux falls under this category from a user's
perspective unless you are the superuser, because the only schedpolicy
to available to ordinary users is SCHED_OTHER.
=> You have to cope with SCHED_OTHER's non-deterministic run-time
behavior across systems.
> > * Some schedulers require special permission (eg. root) or system
> > settings on some systems.
> Linux for one is in this category.
Solaris is another one.
> I have written code to ignore
> the EPERM/EINVAL errors from Linux if you try to do a
> pthread_setschedparam
> for SCHED_RR. It is the same for SCHED_FIFO.
Then your application most likely will use SCHED_OTHER and the run-time
behavior will be random across different OSes.
Fortunately, most *nix-ish schedulers are similar enough for SCHED_OTHER
to provide a sufficient approximation of the desired scheduling in most
cases ;)
Ralf
