POSIX message queue changes from 20020301?
Jay Monkman jtm at smoothsmoothie.com
Fri Dec 6 20:12:33 UTC 2002
Jay Monkman wrote:
> I'm trying to update my application from the 20020301 snapshot to the
> latest one, and some code that uses POSIX message queues now fails.
> I create and open a message queue for read/write. Then I open it again
> (as in another thread) write-only. When I write to the second instance of
> it, I get an error - "Bad file number".
I've looked at this some more, and I think I know what's going on, but
I'm not sure.
When mq_open() is called the first time for a queue and O_CREAR is set,
it creates the queue, and eventually calls _Objects_Open(). On
subsequent calls to mq_open() for the same queue, _Objects_Open() is
never called. When I later call mq_send on the 2nd queue descriptor,
it can't find a reference to the object since _Objects_Open() was
never called.
I'm guessing that _Objects_Open() should be called for the 2nd descriptor.
Is that right?
Jay Monkman	    The truth knocks on the door and you say "Go away, I'm
                    looking for the truth," and so it goes away. Puzzling.
		     - from _Zen_and_the_Art_of_Motorcycle_Maintenance_
