The Great Watchdog Hack
Paul Evans
paule at martex.gen.oh.us
Mon Dec 9 19:30:20 UTC 2002
Joel Sherrill wrote:
<snip>
> It is OK if the memory has already been zeroed by something else. Over
> the years,
> I have seen a variety of systems which did ensure that memory was zeroed
> before
> control was given to the application. These tended to be systems with
> ROM
> monitors or boot loaders but it was common enough that we decided to let
> the
> BSP specify if RTEMS was clearing memory twice.
I'll try this next chance as I already zero RAM in start.S before
copying .data from flash.
<snip>
> If possible just using a longer timeout for the first time would be a
> possible
> solution. This would be the simplest thing.
It's already maxed out. *sigh*
> There are some pretty easy places to stick the reset if not in a kind of
> order that reflects how easy I think they would be to insert compared
> to how effective.
> + if clearing memory is the big culprit, have your own memory clear
> routine that zaps N bytes, then touches the watchdog.
> + touch it before calling rtems_initialize_executive
> + put a hook in for every init hook to touch the watchdog (pretasking,
> predriver, postdriver, etc.)
> + let every device driver init touch the watchdog
Aside from being ugly doesn't putting a strobe infront of
each *_Initialize function inside rtems_initialize_executive_early()
provide pretty good coverage? I could add the init hooks and driver
strobe just in case.
I liked Chris John's idea of using a timer interrupt but it's not
clear to me if it's possible to use it early enough in the boot
process to make a difference.
I'm hoping eliminating the workspace clear fixes it. If not, I'll need
metrics, time to get out the logic analyzer..
> I suspect that the big time culprit is either zapping memory or
> dead time during device init. So figure out how much those are
> and work it out.
I was already strobing the watchdog during the delays I have
in device driver inits, but I'll look again at this.
> > Chris Johns, cjohns at cybertec.com.au
-Paul
